How to make a 13.9 second N/A
RIPDOTCOM
157
Tallahassee, FL
Thats all I want, i swear I'll be happy with a 13.9 I saw that ther eis a guy over at supras.com that runs 13.9 with a N/A Let me know if I am on track with the following mods
16' Timing Advance (done)
Cold air intake (done)
Temp mod (done)
G-force radials (done)
Headers
2.4"/60mm HKS Sport Exhaust
AFM Fuel mod (done)
Cat deletion
s383mmber1
3,614
Somers New York
Temp mod (done)
Headers
AFM Fuel mod (done)
Cat deletion
AFM fuel mod? Explain please!
13.9 if a very hopeful time for your mods. Im running a full exhaust, ported and polished throttle body, intake manifold and Y pipe. K&N fipk all new gaskets, new clutch, and a short throw shifter and test pipe and i would be AMAZED to break into the 14's
-William
8,897
There is a spring inside the airflow meter that is wound and puts tension on the door. Loosening it allows the door to open earlier, tighten it opens more difficult. It is sort of like trimming the airflow signal plus or minus on a GTE. Mark it before you move it. Do not touch anything else inside. A new meter is like $700 from Toyota. And use Toyota FIPG to reseal it.
Leaning the engine can help stock power levels. It will raise combustion temsps. But that could burn a non metal headgasket.
