how to install aeromotive FPR?
suprafanatic
1,607
Greenwood, IN
i just got a aeromotive fuel pressure regulator for my car, and i was just wondering if anyone had instructions for the install? or if you could simply explain it to me, thanks!
Mischief7m
Broke and Lovin It
Sep 13, 2007
507
Central Ma / Cape Cod Ma
did you get like the driftmotion kit, or just the fpr?
if you got the kit, you just run from the return line port on the fuel rail, to one side of the regulator
then from the bottom of the regulator to your return line.
then pick a vacuum source, set your desired pressure, then connect the vacuum line.
but before you start the car just switch from off to on on the key a few times to prime the system and check for leaks.
americanjebus
Mr. Evergreen
wa.
Mischief covered it but heres a visual
boostaddict
96
connecticut
if you dont have the kit what do you do with the jtube? i have the regulator and steel braided hose and the fittings but what to do with that jtube
americanjebus
Mr. Evergreen
wa.
If you can eliminate it do it. Just hook a hose directly to your return line and leave the jtube on there to serve as a block off plate.
It acts as a restriction to flow because of the tiny little hole in it. Or you can just drill out the little bottle neck it has.
