How to avoid or minimize the chance of rod knock
QWIKSTRIKE
475rwhp459torq an climbin
Apr 3, 2005
1,172
Some where out there
How to Minimize or Eliminate the chance of Rod Knock
Well I hear many people talk of Getting rod knock after doing a engine rebuild. After doing a successfull rebuild, and then gettting knock I was a little worried. Well my knock was caused by a faulty oil pump drive shaft that caused a lack of oil.
It always seems to have a reason, but no one ever looks to themselves as the problem. Don't forget it all comes down to lubrication, machining, and poor assembleing. The bearings ride on a tiny film of oil. running rich, can cause poor lubricating problems. The gas runs past the rings and in to the oil making kerosene, this kills the bearings. Oil that is too hot can also cause bearing fatigue, and failure. Also running to thin of a viscosity, and poor filtering can contribute to bearing failure. Collectively the last problems mentioned can give a proper rebuild a knock. Let's look at what I see as things that can cause rod knock.
1. Faulty oiling system lack of oil, low oil pressure, not enough oil
2. Improper Machine work. i.e. poor tolerances Many machinist don't recognize that the specs must be very precise or there wll be failure
3. All components must be inspected for clearances, and in my opinion don't accept anything that is just within tolerance when it comes to rods.
4. crank must be cut and properly sized by a very reputable machinist. Ask questions you know the answers to. See if his answers match up to what must be done.
5. get good bearings. Clevites are fine but they are reboxed and are farmed out to other bearing companies. My mains were made by global, and my rod bearings made by NDC. They came in a clevite77 box. Call them and ask them if you dont believe me. They don't always use the same companies I hear. I also am told that the ndc bearings are .001 of an inch unersized. I hear that ACL are great and is moslty used in the MKIV's along side of clevite77's. This is your choice choose wisely!
6. Get new rods, or get them cut and resized no matter what! New they ar 36.00 cut they are 15.00 per rod. Arps cost 40.00 and are an option for added insurance.
7. use boots or tape to keep rod bolts from damageing crank!
8. use moly asembly lube that the machinist will give for free. Mine does.
9. DON'T mix end caps, and rods! this will cause knock! some of you don't know this, and after hearing "It knocked after starting" this is my guess a good reason why it knocked. Then you blame the car for your error.
10. after rods areinstalled in the block use a good torque wrench and torque to spec of factory or arp spec reccomendations,and use plastigauge to check clearance
11. Never put in an old oil pump unless you want to do this again!
12. get new oil filter adapter, or go relocation kit and inline thermostat and cooler. The old adpter has a relief valve, and spring which wears over the years. After 150-200k it must be replaced, or you do this again because of low oil pressure. After installing my kit my pressure rose 12psi.
13. Properly tune the engine especially when upping fuel pressure, and adding bigger turbos!
14. Keep oil levels filled as mentioned by Drjonzes, add an extra quart!
15. However; One point is missing that you need to know. The bearings will be different sizes if the crank isn't cut to one size say like .25mm called 10 under. This presents the problem of a newbie, or even a seasoned mechanic mixing up the bearing sizes, and getting rod knock. To avoid this each rod journal must have the proper bearings marked in some form or fashion. You can have him list the sizes for each journal 1-6 in order so you won't have this problem.
When done correctly this procedure will give you a great knock free engine until you run low on oil.
If I have left anything out be sure to chime in.
Anthony
QWIKSTRIKE
Apr 3, 2005
1,172
mkIIIman089 said:
lol, I was waiting for this to show up here qwik...
I have been so busy trying to get my new setup and rebuild going that I hadn't been here in a while. When I originally tried to post I could not get into the forums until I got a little assistance from my good buddy Grimjack. :drink1: :wavey:
Something I'm using to good effect is the Moroso 3 QT Accumulator.
It plumbs into the oil system and charges on engine startup and holds 3 qt's in reserve in case there is an interruption to the oil supply.
If there is it pumps this oil into the main oil gallery and adds insurance against the dreaded rod knock!
It also helps in engine shutdowns as the system holds pressure for some time and this means the Turbo has a supply while it spools down and will help prevent the oil in the turbo boiling then coking which is what kills seals and bearings.
Adjuster
The Canton version works well too. If you have a valve installed, you can close the valve before you shut down, then open it before you start up the engine, and pre-lube the motor every time. (Should minimize any wear, the only time my engine is "dry" started is after oil changes and I dump the accusump.)
They make a one quart sump you can plumb into your turbo line that will automaticly cool down the turbo with every shut down.. I've run out of room in the engine bay however... :) But I still might do it one of these days.
Makes a nice speaker grille too.
cuel
1,536
Baytown, Texas
You also need to prime the oil pump before you turn the engine over. I like to fill it with oil(dump a qt. of oil in a CLEAN coffee can, stick the pick up screen in there, spin the pump gear until oil comes out the other end), install it, the pan, and the rest of the oiling system components, then turn the oil pump gear(before installing the timing belt) to prime the oil system as much as I can.
Something I always do with a fresh motor is pull the fuel pump fuse/relay, and unplug the dist./cps, and spin the motor over (without the spark plugs in it) until it builds good oil pressure. I'll usually let it spin for a min. or two after the pressure reads on the gauge, then install the plugs, put in the fuse/relay, hook up the dist./cps. This is the very last thing I do before starting any rebuilt/used motor.
