how much should i tell the machinist to deck my head for a 2mm hks mhg
chefma70
404
Florida
im ready to take my block and head and block to the machine shop to be decked how much should i get decked off?i plan on pushing mid 400's through college and going 600+ when i get out of college.what ever else u need to know to give me a exact number ask.the motor is going to get done at racetech.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
dumbo;1301292 said:
I would assume the minium to get the head/deck true. Then pick your headgasket, not the other way around.
This.
Tell them to take off the minimum they can while still getting you a perfect sealing surface. Then get the numbers for what they took off and use that to calculate your head gasket thickness.
If you've got the wrong one, sell it and order another one.
chefma70
404
Florida
rameans23;1301367 said:
im in the same boat here....i heard from jon(MDC) to take the front plate from the motor in with it too so they can make sure to get it at a perfect 90 degree angle
im jusat gona leave the front plate attached i think thats what ur suppostu do?
chefma70
404
Florida
GrimJack;1301337 said:
This.
that makes perfect sense. ima do that
