how much nitrous?
DEFIANT 7M
101MM stroke of INSANITY!
Nashville/Miami
siman said:
so being retarded is ok? :momaru:
but on a serious note, thats some good info!
but still.....word from "da streetz" says BABIES USE THE BOTTLE.
-Jonathan
Girlie men use hair dryers :icon_razz
DEFIANT 7M
Nashville/Miami
Michael90t said:
Copper plugs are a must.... your plats and irridium plugs have a much finer tip and will heat up very quickly in a nitrouse app... which will cause detonation and the such..... there are pluggs that are made for nitrous with nice big fat tips on them so they can absorbe the extra heat but really any quality copper plugg gapped correctly will work just make sure when your tuning them
The Autolite "race" plug is good. The article also pointed that out. Just by luck that is the plug I have been using with no problems.
Quote:The Autolite race plug has a minimum length of side electrode with a rounded end terminating over the side of the center electrode. Just what is needed for a nitrous application.
Dirgle
Conjurer of Boost
Pauma Valley, CA
I have followed the bottles are for babies mantra since my domestic days. I never did like the idea of having a limited time duration for power a increase. And then having to refill. So I never really got into it. But I do have a question about N2O. How is a dry shots need for more fuel from the cars fuel system taken care of? N2O is basically unmetered air. How does one keep it from going lean? If you don't somehow tell the ECU to add more fuel you should run into a lean condition pretty quickly. Is that assumption right or wrong?
DEFIANT 7M
Nashville/Miami
http://www.holley.com/HiOctn/TechServ/TechInfo/NOSTech1.html
http://www.holley.com/HiOctn/TechServ/TechInfo/NOSTech7.html
http://www.holley.com/HiOctn/TechServ/TechInfo/NOSTech4.html
M
MisterTurbineTwister
Guest
Defiant is right on the money with the fuel-oxygen level. You just run richer on the fuel side.
This is yet ANOTHER reason why having Nitrous in a street car is a joke. You have to run lower compression, richer fuel mixture and retarded ignition timing. These all add to poor fuel economy and loss of horse power when you are not using a forced oxygen induction system, being nitrous oxide, propane (in a diesel) a turbocharger or a supercharger.
It essentially does the same thing to a combustion that high amounts of boost does, only in a different dose amount and atributes to higher BTU levels in the fuel, hotter and quicker combustion conditions and nitrous itself is pressure sensitive to temperature. Nitrous oxide increases or decreases 1-2 PSI with every single temperature differ in Ferrenheit. This is about 10-11HP increase or decrease with every degree of bottle temperature increase or decrease.
Example:
72 degrees F= Advertised HP shot (say it's an advertised 50hp@72 degreesF)
+1 degree F= 73 degrees F= 65-66HP
-1 degree F= 71 degrees F= 44-45HP
+10 degrees F= 82 degrees F= 150HP
These numbers change so drasticly that a 5 degree temperature change inside the bottle can be volatle to your engines combustion condition and the only real way to know what to expect is to use a bottle temperature controller (heater/cooler) for the correct temperature for your desired HP shot of nitrous. This is usually monitored and controlled by the same nitrous computer that controls your A/F ratio, timing and shot PSI...
You wouldn't boost your car without metering the air/fuel ratio, so why would you run nitrous oxide without a controller made for it?
This all means that if you run a car that has nitrous oxide, even if you use it at WOT and when you're supposed to inject it, whenever you're not using it, your car WILL run like shit. This is because the fuel level, timing and compression (if you buy the right low compression forged pistons for nitrous) are all tuned for the nitrous and can not run correctly without it.
Even if you have a controller for the timing nitrous/fuel and nitrous temp, if you have the right pistons for nitrous, there is no adjustment in initial compression ratio, so you will still see some loss in HP when you are not using it over the same engine that does not use nitrous to begin with.
I have seen idiots throw their bottle into a bathtub full of 140 degree water and run... guess what happened?
This is ALL aside from the govorning factor that it WILL take thousands of miles from the lifespan of the engine as sacrifice for using nitrous oxide under the correct methods.
Nitrous is for race cars that only see minimal running time and maintained with a magnifying glass after every race.
M
Guest
The drivers on the Fast and the Furious also park and drive in formation, like a flock of geese. Who the fuck had that idea? lol... Makes you wonder how they decide which kanji tatooed Linkin' Park listening suburban brat leads the pack. Do they have pecking orders for who has the most amplifiers, decals and neon lights attached to their Civics?
Vin Diesel can taste a doberman's ass.
s383mmber1
3,614
Somers New York
"mommy, but i wanna be JUST like the guys from the fast and furious!"
"Why cant i have flashy lights and hub cap spinners"?
:biglaugh: :biglaugh:
Fuzz420
Are U Here 2 take My Baby
Ive also tossed the idea, of installing nitrous in my car.Ive done reading from the forums and how it works and such, and i feel its simply not worth it.50hp shot would come in handy sometimes.Overall in the long run, it would have been smarter to save the additional money and turbo my n/a.I looked up kits and i found this one a few months ago.Its seems to be the ideal kit if someone wanted to do it.Venom Nitrous Kit
