How much fuel pressure to run?
suprafanatic
1,607
Greenwood, IN
i just bought a aeromotive fuel pressure regulator, i have the lex afm and 550cc injectors, i also have a wideband and safc. i was just wondering as to how much pressure i should have the regulator set to? thanks
suprafanatic
1,607
Greenwood, IN
ok thanks for that page. that gives me an idea.. but what kind of fuel pressure are some you guys out there using? with 550s and all the other supporting mods?
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
Its my understanding that with your setup you will want to follow the TSRM guidelines.
I will be running this set soon as well and have done some reading on this.
Like Grim said, start there. See what happens.
suprafanatic
1,607
Greenwood, IN
ok. so what is the point of running an aftermarket fuel pressure regulator if you have it set at stock setting? sorry if thats a stupid question..lol
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
Because you have no control over the stock one.
Biggest reason is looks actually....:naughty:
jdub
Feb 10, 2006
10,730
Valley of the Sun
grimreaper;1133401 said:
im at 26 or 25 vac on and low 30's vac off. still in the high 9's at wot
Pretty close here (27 psi vac on). Mid 10's on the AFR at WOT.
FP with the Lex/550 combo is a "global" correction. To get a true tune, you'll need an AFSC or similar.
grimreaper
2,180
Dallas
how much boost jdub?
im hoping my massive exhaust leaks had an affect on my af ratio in open loop, i hate to keep dropping the fuel pressure...
jdub
Feb 10, 2006
10,730
Valley of the Sun
16-18 psi on an SP61...more than that and I hit fuel cut. I'm moving to a completely different set-up though...I feel the same way about dropping FP and this is still pig rich.
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
The previous owner of my car installed dual walbros and it is set to 50psi. The fuel pressure up VSV line has popped off a couple of times under boost, but I've now clamped it. What's the lowest I could set my pressure to so that it wouldn't be an issue if the fuel pressure did not go up under boost? I imagine 50psi with dual pumps would be hard on the pumps?
Will changing the psi affect my current tune? I have similar mods to the original poster.
How is a FPR supposed to function? Is it one set psi at vacuum, and one set psi at boost, or does it gradually adjust pressure in a linear way based on the vaccuum or boost?
grimreaper
2,180
Dallas
duals is a LOT of fuel, and at 50psi, at 14lbs of boost thats 64psi of fuel. sounds like the tuner or who ever set it for static pressure.:aigo:
AFPR= vacuum decrease/ pressure increase, fuel pressure rises and vice versa.
Adjusting fuel pressure is effectively adjusting your mainscale. It drops it across the board which will mess with your tune. I have ONE walbro at 25 psi of fp and it sits perfectly at 11.8-12.1 afr (back up to 27psi for safety) and NO piggy back or tuner. I imagine the amout of mainscale adjustment that your tuner had to pull was quite large,
**how are you measuring the fp pressure? vac on/off?
