How much did u pay for 7m rebuild
Zrain25
639
Pelham,New Hampshire
Hey I was wondering how much all of you guys paid for ur 7m rebuild
I'm looking at getting the head and block machined.
Cylinders honed
New rings
New bearings
MHG
Arp studs
And all parts hot tanked
Also the would be assembling the block I will be taking the head off.
Thanks what Im looking to get done but I would like to hear what you guys paid Just so I don't get ripped off
Thanks guys
Suprapowaz!(2)
2,870
San Antonio, Tx.
Roughly $835 for a shortblock rebuild. I don't have the receipt in front of me.
I brought the shortblock to them disassembled. Timing cover was on the block, but forgot the timing belt tensioner on it.
All parts hot tanked.
Crank cut and polished 0.010/0.010
Bored 0.020 over.
New OEM pistons & rings.
Stock rods resized/reconditioned.
New rod & main bearings.
Rotating assembly balanced.
Decked with timing plate.
New freeze plugs.
They assembled it. ($150).
If I were to have assembled it myself it would have only been around $685. They have a good reputation, and the local "performance/speed shops" farm out their work to them. As a matter of fact a performance shop here in town was going to charge me in the neighborhood of $1400 for the same stock shortblock rebuild. They told me because it's an import and I was going to race it they were going to have to be very particular on all clearances which was labor intensive. A friend of mine told me about E&E Machine shop and I took it to them. While my engine was being rebuilt I was in there from time to time chatting with the counterman about how things were going. I saw the guy from that "performance" shop show up to E&E Machine and dropped of a few engines to get rebuilt, and picked a couple up. Talking to the counterman he told me that they farm out all of their work to them. The same guys that quoted me $1400 for my rebuild would have taken it there and had it done much cheaper, and profiting off of me. The counterman also let me in on a secret about other performance shops that farm their work out to them, and other local "regular" machine shops.
If you don't see a fully equipped machine shop in a performance/speed shop that you're considering getting your stuff done at then you can bet they're farming out their work and charging you a premium. Cut out the middle man and find out which one of your "regular" shops have a good reputation.
Prices here in town are cheap cause there's over a dozen reputable machine shops available to do the work. In smaller towns you may not have that luxury and have to pay dearly for machine work.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,277
68
Atlanta
I had the following done:
Hot tank
Line bore
Bore/ hone
Crank polished/ balanced
Rods checked
Rod/piston sets weight matched
Deck cut for mhg with timing cover
Shop purchased arp mains and all clevites
$1150
No assembly
Pistons and rods purchased seperately.
zby67
173
Texas
i never did a full rebuild but just the head alone costed me 1,200$
5 angle valve job
bowl blend
resurfaced
new cams
valve seals
cleaned/media blasted
vacuum and pressure tested
new shims
forgot if any of the springs or retainers were replaced...
Zrain25
639
I called a few machine shops around my area I got 1200 to 2400 dollar quotes. My cousin got his 7m head done at the cheapest place. All they do is engines and he quoted me around 1200.
I think I could save alot of money if I put the motor together my self I know I could do I just never did it before.
I plan on getting it rebuilt next winter so I got some time to decide
mcammarn
matt
Feb 24, 2012
668
olympia wa
Here's my build receipt minus head work. That was done a different day
