How many quarts of oil?
cwapface
Supernerd
Eugene, OR
www.dylanwiggins.com
as far as pressure goes, I am seeing ~50psi @ 3k rpm when it is cold in the morning, and it drops to around 40 when it is warmed up. At idle it is just south of the 20psi line, and then as best as I can tell it falls to around 10-15 when it is warm.
Idealsupra
Orlando
www.tampabaysupras.com
shaeff said:
i thought the only difference between the N/A block and Turbo block was:
lack of oil squirters
pistons/compression ratio
and maybe a few fittings for oil lines and whatnot.
i didnt think that an N/A block would affect oil pressure... unless the N/A oilpump pushes more oil?
oh yeah, i have always run 6 quarts of oil, both in my N/A motor and in my Turbo motor.
-shaeff
by block i meant the NA oil filter block...which doesnt have the gay relief spring and oil cooler lines etc...
MKIIINA
Destroyer of Turbos
Plano, TX
I do Mobil 1 15w50 and have been more than pleased with the results. @ Cold idle i see just a touch over 20psi of pressure. At warm idle its just under 20psi @ 3k in 5th i see about 60psi.
jester1341
topless and blown
Western Maryland
i use mobile one 10w30 and get about 10-15 idleing and about 40 at 3K and up
should i change my oil???
i know i leak, and hopefully after the head job[also doing front main] i won't leak, but should i change oils??
john
Idealsupra
Orlando
john
i think if you wanted you could try to move up to the 20w50 and see if it gives you a few more psi and maybe some btter "reaction" to acceleration...
however from what you said you seem to be fine...
