How many qts of oil in dry R154?
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
Good morning!
Finally putting the final touches on my car getting ready to start it tomorrow, but first I need to put in some gear oil.
I think it's between 3 and 4 bottles, but I couldn't find the information in the TSRM.
How many should it be for a dry transmission?
Thanks!
-Brent
I have the redline in mine, but I think I put 3.2 in it. Should I put the rest of that quart in there? I still haven't put it all back together yet so I can get to it in a matter of minutes.
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Ive put in 3.2 qts before and have had oil all over the driveshaft....
Make sure ^ you do as told above. Take out the actual fill plug up top and fill through the shifter.
When it starts to oooze out of the fill plug, you're golden - 3 qts or not.
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Yeah, I bought about a gallon of the stuff because I planned to flush the diff. as well.
Thanks guys!
I definitely over filled my last transmission once, and it was awful... huge smoke screen coming from the tailshaft. :rofl:
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
I used 3.2qts.
Just finished putting mine together last week and I plan to check all the fluids today to see exactly how filled it is.
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
I did it the hard way and filled it from the fill plug and waited for it to come out so I knew it was full. Then I found out the way from the shifter. Oh well.
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Yeah, I finished filling it earlier... just put in 3.2 from the shifter, worked last time. :)
Just had to replace the knock sensors though, the pre-89's must be different, I was getting codes for them.
Erasing them now, and going to try my 89 knk sensors.
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
Starting it up today or tomorrow?
Let me know if you could use any help, I'd love to see your car Brent.
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Car started up today... and once I put my old knock sensors in this block it ran fine.
I need to triple check the cooling system. After spending $100 some dollars on my nifty cooling system pressure tester, I like to use it!
Screwed up a little bit, I was so busy checking for leaks and getting it to idle on the fuel pressure that was SKY high from before my car blew up... that I didn't top off the radiator.
I shut down at 150 degrees F when I observed the upper hose crinkling...
Everything should still be fine, I'll top it off and try to burp it.
MassSupra89: If you're in the Greensboro area and want to possibly meet up tonight... If my car is all sorted out I'll take it out to Main st. in Highpoint.
Guyana00
Droppin that JZ in soon!
Apr 18, 2007
1,208
Brampton, ON
That's how life is :p . The good part (for me), is older supra owners do a lot of trial and error or testing of their own to find the best methods for newer supra owners, like myself :)
