Supracentral said:This should help end confusion on these Wastegates:
HKS Wastegate Springs
Standard Wastegate Springs:
5.7 psi = White Spring
6.4 psi = Red Spring
14.2 psi = Yellow Spring
20 psi = Purple Spring
GT Wastegate Springs:
Silver (Center Spring)
White/Blue (Outer Spring - Soft)
Red/Green (outer Spring - Hard)
8.5 to 14.2psi = White/Blue Spring Only (no center)
12.8 to 18.5 psi = Red/Green Spring Only (no center)
18.5 to 24.2 psi = Silver Spring AND White/Blue Spring
24.2 to 29.9 psi = Silver Spring AND Red/Green Spring
Racing Wastegate Springs:
10 psi = Yellow Spring (Same spring as used in Standard WG [note different boost level])
14.2 psi = Purple Spring (Same spring as used in Standard WG [note different boost level])
18.5 psi = Gray Spring
22.8 psi = Brown Spring
Hope that helps.
Any idea if those colours/values apply to the knock off HKS wastegates? I got a few different springs with mine and have no idea what they are rated to.
