s383mmber1 said:15 psi, stock headgasket, no wideband = NO!
Nick M said:Really, why is that?
MidShipCivic said:I just did it once and the car instantly hit 130mph, I didnt do it again it's doing 11 psi right now.
Vacumm at idle is 11 in/hg.
Crazy white bluish smoke on decel thats the turbo seals? The charge pipe that goes across the valve covers are clean, but the outlet pipe right after the intecooler it's oily inside.
Boost Lee said:If you've got oil inside of your intercooler, you've most likely got a bad turbo.![]()
How could that be sarcasm? You suggested tech advice of some sort, I wanted to know why he needs it.s383mmber1 said:Is that sarcasm? Or are you really asking why?
MidShipCivic said:I just pulled off the compressor outlet pipe stuck my hand in there... its not oily but there's oil in there and shaft play is little.
The smoke I'm describing is just like this guys Supra.
http://www.youtube.com/watch?v=fkXEK_XfE8s
supradan22 said:NVM that car should have a LEX AFM not a FCD with 550cc injectors I miss that car it looks like it was kept in good shape.
Either way you got a good deal on that car.
But get a Wideband ASAP.
Boost Lee said:
