jdub said:Stock rods and pistons are good to around 500 HP safely. That assumes a re-build to put all bearing clearances into spec, decking the block & head for a MHG, balancing the crank/rods/pistons. Fuel upgrades to an adjustable FPR, walbro pump, 550 cc injectors, and removing the "J" tube. Intake upgrade to a Lex AFM....that will allow you to get to 18 psi of boost before you hit fuel cut.
Or MAF-T in place of the AFM.
jdub said:If you are planning to bolt on a new turbo on a 100,000 mile motor and turn the boost up...you are asking for a BHG, rod knock, or throwing a rod out the side of the motor. Been done many times.
Yeah, tired engines + more boost = broken
jdub said:If you are going to put on a MHG, you have to pull the motor to get the block decked to the RA spec for the MHG you use.
You speak the truth.
