How do you remove the wheel hub/bearings?? Need Help ASAP Thank You
5
yep, they have to be pressed per the TSRM...
really sucks, but it's not too bad to have it done (had to change the axle bearings on my old truck, they had it done in a few hours...)
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
i am thinking you do have big eghough of hammer if you can get the tie rod off need a good one that will amke you elbow hurt a tacking nailing hammer will not do
CampbellsChunkySoupra said:
well, ive basically been beatin the hell out of the tie rod and everything in the wheel well. its insane. nothing will budge. here are some pictures.
can anyone get me the part number for this nut that goes on the back of the hub? it is stripped out pretty badly.
here is a picture of what im dealing with. i can not get the damn hub out of the fricking car. and hardly anyone is replying!
Piratetip said:
Ah yeah I can...:)
Castle nuts for tie rod and balljoints?
If so,
90171-14003 Upper
90171-16003 Lower
90171-12028 Tie Rod
Nope I'm talking about the big arse 30mm+ nut that holds the front hud in it's staked and needs to be replaced each time it's removed. ;)
supraguy@aol
Well-Known Member
Dec 30, 2005
4,270
64
Atlanta
I just did the driver's side hub, the tie rod came off easily enough with a tie rod fork & 5lb hammer. DONT hit the threaded section unless you plan to replace the entire outer tie rod, which ISN'T a bad idea if it's original. As for the spindle itself, you have a fun time getting that out of the bearing, as it's pressed into the bearing just as the bearing is pressed into the hub. If you get a two or three arm puller on the back just right, you can press that spindle out, but you WILL need a press for the bearing itself.
Piratetip
Far From Maddening Crowds
1,179
70
MKE, WI
I already posted the big arse nut it was the #90179-24005 :joshers:
best be eating your soup!
Jan 28, 2007
620
Norwalk, IA
www.dragsource.net
well Krikey!
i ordered the nut. its $4. a new wheel bearing [which im sure ive destroyed] was $93 from toyota, $50 from oreilleys, $42 from autozone. talk about gay!
ill have the assembly off tomorrow and get it all pressed out. if i cant get the tie rod off, im going to white out it, undo it and take it all into my machine shop. then ill just go get it all realigned while im at it. hell, might as well by some 275s for the rear too. oh, and a new turbo. then ill be good.
all this crap is setting me back another paycheck. it sucks... im so sick of this car! something else seems to break every other day. [please, no comments to the previous statement]
supraguy@aol
Well-Known Member
Dec 30, 2005
4,270
64
Atlanta
well Krikey!
i ordered the nut. its $4. a new wheel bearing [which im sure ive destroyed] was ... $42 from autozone. talk about gay!
ill have the assembly off tomorrow and get it all pressed out. .. . then ill just go get it all realigned while im at it....
I count $4, $42, and I'm guessing $40 pressing, $75 full alignment.
How much are your paychecks?
