How do you remove the wheel hub/bearings?? Need Help ASAP Thank You
Lee_MA61
Leon Wilson III
Jan 31, 2007
148
Norwalk, IA
I'm probably posting this in the wrong section, but I thought general would be better than the completly wrong one.
Anyways..
Tyler (CambellsChunkySoupra) and I are trying to remove his wheel hub but the wheel bearings are giving us trouble. We really need help! So if anyone could give us a step by step run through of it's removal that would be appreciated!
Any help is welcome!
Thank you!!
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
hummmmmm
well to get your tie rod end of is very simple get nice hammer beat the liven crap out of the nuckle and the tie rod end will pop out
as for the wheel baring ummm have nto done one in less time puller is best but can be done wiht hamer and vise and some pipe
instal use vise or tap it in wiht hammer
CampbellsChunkySoupra
best be eating your soup!
Jan 28, 2007
620
Norwalk, IA
www.dragsource.net
well, ive basically been beatin the hell out of the tie rod and everything in the wheel well. its insane. nothing will budge. here are some pictures.
can anyone get me the part number for this nut that goes on the back of the hub? it is stripped out pretty badly.
here is a picture of what im dealing with. i can not get the damn hub out of the fricking car. and hardly anyone is replying!
Jan 28, 2007
620
Norwalk, IA
www.dragsource.net
ok, all this hammer tallk isnt doing shit. do i hit the hub from behind or what? does the bearing and everything just "pop" out? there has got to be something. the TSRM said there is a snap ring in there and i cant seem to get anything out of it. and now its dark. time to kill myself.
To pop the Tie rods/ball joints hit the SIDE of the knuckle with a hammer.
If you don't have access to a press it's going to be much easier to drop both knuckles and take them to the local suspension/brake shop and have them press the old ones out and the new ones in shouldn't be more than $30>$40 and will save you a shitload of grief when you slip and trash a bearing or hub.
Jan 28, 2007
620
Norwalk, IA
www.dragsource.net
so ill just take the whole assembly off tomorrow. but ill need that stupid nut that goes on the back side of the hub since mine got stripped out pretty bad. so basically i need the toyota part number for that too. ill have to run up there tomorrow. right now im car less and thats gonna suck. but u definatly think pressing is the way to go? i hope my machine shop can do that.
Piratetip
Far From Maddening Crowds
1,177
69
MKE, WI
A press is one of the most basic tools a machine shop will have. They better know.
Part # for Steering Knuckle Nut 90179-24005
Piratetip
1,177
69
MKE, WI
Ah yeah I can...:)
Castle nuts for tie rod and balljoints?
If so,
90171-14003 Upper
90171-16003 Lower
90171-12028 Tie Rod
