heh. MOST LIKELY you should be getting your motor with a turbo, also the timing belt cover has a sticker on it that says 7M-GTE.
the intake manifolds are different. the GE has a ypipe going into the plenum, the GTE has a straight pipe that has a 3000 etched in it in big numbers.
the GTE has a coilpack which will be sitting on top of the valve covers. it also has a CPS instead of a distributor.
if its a complete long block, the most obvious sign that it is a GTE is the big piece of metal hanging off the exhaust side of the engine...
