i just got my motor back from machine shop i got the motor all together but i need to know how to position the cam sensor i have stage 2 cams also i dont know if that makes a differance.thanks walt.
whats e1 & te1bowsercake said:Its easier if the motor is not in the car. take off the plastic dust cover and make sure that the insides line up like they do in that write up. set base timing with the E1 and Te1 jumped.
so if i have #1 cylinder at tdc & put it to where the two red lines are i should be good.regards walter.Mk3runner said:
what r u talking about?james_9876 said:Basically jump the terminal where you would check the check engine light (codes) I believe.
