americanjebus said:i hope your not reffering to armorall, it has alcohol in it which means if you stop useing armoral it will end up cracking your dash after long term use, the thing with armoral is it will do wonders for a while but if you dont continue to use armoral more and more often the dash will start to dry cus of its need for that alcohol refurbrishing, (we already had a thread on this in the last site before we got hacked)
use something like meguires cus its not alcohol based and you can stop using it without the problem of the dash drying.
i dont mean to say that armoral is gonna turn your dash into charcoal but its not AS good as some other non alcohol based ones.
mkiiSupraMan18 said:
Makavelli said:Meguires is good, also, Turtle wax makes a really nice product you can use on leather, rubber, whatever and it'll actually lock in moisture as opposed to rob it.
wow thnx for the heads up. I used it today already but from now on I will switch to somethign else thnx for the heads up man.americanjebus said:i hope your not reffering to armorall, it has alcohol in it which means if you stop useing armoral it will end up cracking your dash after long term use, the thing with armoral is it will do wonders for a while but if you dont continue to use armoral more and more often the dash will start to dry cus of its need for that alcohol refurbrishing, (we already had a thread on this in the last site before we got hacked)
cwapface said:How did you get your black plastic parts so shiny? Paint?
D34DC311 said:is this a theory? or have u done this. seems like it would work but..?
