How difficult is your 5spd to get into gear position?
quake
toyota tech
Apr 13, 2005
619
r.i.
assuming u all race the mt-90 is a better shifting fluid because of its propeties. If you can rebuild your trannys with new syncros. A syncro is a brake it helps match gear speeds so you can shift easy. As the syncro wears out the brakeing action begins to get worse. With new syncros you will be able to shift quickly this will help with lag and winning the next race
MKIIINA
Destroyer of Turbos
Plano, TX
for reverse remember to go second and then reverse. for some reason this helps out. 1st has a lock out if your going too fast. past that mines fine? :shrug: a little notchy but nothing terrible. most of the new cars have short shifters (viper, s2000) so theres just alot less travel, might have something to do with the perception
