How long does it take to replace 1 jz starter? did anyone do it before? Also, do i need to replace the solenoid too, or just the motor if the car just clicks and will not start.
well if you get a starter from toyota, pepboys, advanced auto, car quest your going to get the whole starter as a unit not little pieces that have to be put together its two 14mm bolts on the tranny housing then unclip the wiring harness.
Thanks guys. very helpfull. I spent the whole day trying to start the car yesterday. 12 hours later it started, it was 12.30 am ofcourse but at least something. Now it starts fine again. Also, it was giving me engine code 12 last night.
What year SC, I know it sounds stupid, but I'm just wanting to make sure. I just had my solenoid replaced and it is still acting up, so I'm going to just replace the whole thing, even though I was told all I needed was the solenoid.
you can replace the contacts in the starter also just did it to mine. it took me overall 1 hour to remove, rebuild and replace.vthe contact kit is around 11 bucks a piece and you need two.
