i was jacking my car up to purge the cooling system after changing the headgasket, when my jack slipped off of the center crossmember and pushed the rack@pinion lines into the oilpan. it smashed the pan in to the point where it hits the crankshaft. so my question is where is the oilpump/ pickup tube?
i can use my dent puller to pull the pan out, but i dont know if i damaged anything internally.
so should i pull the motor to check? i was going to pull it eventually this fall to regasket and do my 5-speed swap, as it is i have to pull the rack to fix the lines.
pict
pict
