Houston shops
iamshawn
codename: HENRO
Nov 2, 2005
74
Houston
I've got pretty much 2 sets of everything... 2 shells 2 blocks 2 heads etc.. i just need someone to put it all together since i don't have time. Paint and body i've got those taken care of but i need someone or a shop to build my engine and get it all running ^__^
the shells are one 87 and one 90
machined blocked .020 overbore with oversize pistons and balanced rods.
the shaft is from a 6M but also have a 7M shaft also. Have all piston rings and everything ready to be built.
ARP Head studs
HKS 1.5mm MHG
got Freshly rebuilt head ready to be bolted on,
brand new toyota turbo manifold
upgraded 57 trim CT-26
Every thing that cooleeze sells for supra i have (downpipe, test pipe, b-pipe, IC hard pipes with 3000 pipe, hard radiator pipe, and turbo elbow)
Lexus MAF with K&N intake
new NGK spark plugs and wires
new walbro intank fuel pump
new water pump
Total rebuilt auto tranny with new borg warner clutches and gears
whole bunch of other stuff
If anyone know a shop or someone that would be willing to do the work let me know how much it would cost to get everything running.
I would have done all of this myself but i have no time, but i want to have atleast one of these to drive around on the weekend.
I live between katy and alief area... close to hwy6 and clay rd.
PM me or Email ecsdesignz@hotmail.com
NgoFcukinWay
Formerly Got Boost?
Apr 3, 2005
493
Houston, Tx
Chris at Engine Logics FTW. They did a lot of my brother-in-law's stuff, but it ain't gonna be cheap though.
Enginelogics
12201 Dover Street, Houston, TX 77031
(281) 933-2262
I think that's the right address. They will not cut corners at the shop unlike some on the northside *cough*SGP*cough* and they do a lot of top notch work.
GEOSTORM
23
RICHMOND,TEXAS
Enginelogics
(281) 933-2262
how cheap is cheap ?
and what kind of work do they do ?
i need some help with mine i bought it quite awhile back it was running but then it decided to blow the head gasket,i replaced the hg myself ,timing belt water pump ,tensioner,valve cover gaskets (can't get rid of leak ) and set the timing as per the the service manual but the car doesn't seem to have power and then when i hit the gas to wot the car boggs down and does not want to upshift until i let off the gas i'm going nuts over this can someone tell me what i did wrong ? or if i'm missing something also have a stinkin code 52 that i can't get rid of i don't hear any engine knocking noise and the engine idles just fine also replaced the injectors and fuel rail from another supra i have for prts and the same freaking thing nothing has changed for me i'm starting to get tired of dealing with this thing,......can any one help
i'm on the southwest side of houston more like outside of houston i'm five minutes from sugarland my number is 281-638-4328 c if someone wants to hit me with some imfo thanks again very much i appreciate all your help..:cry:
NgoFcukinWay
Formerly Got Boost?
Apr 3, 2005
493
Houston, Tx
if I were you, i'd give'em a call to get an idea of what vital organs you'll need to give up. But just to let you know: I think they're booked until the end of the month cuz my bro-in-law needs to send his in too.
draginassis
houston
hey my dad is a mechanic and he lives in richmon, tx not too far from you. if you want i can give you his phone number. its 281-638-4328. his name is giovanni... you can ask him whatever questions you have. just tell him irvin told you to call him... hope this helps.
