hot engine sputters when started
mmkkpro
19
Morgantown W.V.
Hey guys,ive got a 1986.5 na supra,it starts great when cold but when its hot when i start it ,she sputters really bad and i have to hold gas pedal like wide open for several seconds before it smooths out,but then it runs fine,any ideas?Seems like something in the ful system but im not educated on fuel injection so much,any help would be appericated,thanks in advance ,Mike
MPR
John 3:16
Dec 17, 2011
221
Toronto, Ontario
Mine does the same. It's common. I believe it's from a faulty vsv which is supposed to bump fuel pressure on warm/hot starts to prevent vapor lock. Not a big deal. I just hold a little throttle till it idles smoothly or just drive it.
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
The FP VSV is located under the intake runners toward the front of the engine. The vac line that connects to it may have come off. The end of the nipple on the VSV isn't knurled. It's just smooth so old/dry vac lines slip off easily.
