Long story short I swapped a gte in my na... gte head was toast so I put my na head on. After searching I found lots of info on na cam differences but no info I needed.
Question: Will using a na cam cause a rough idle around 900 - 1000 rpm?
And kinda sounds like a hotrod with cams only reason I ask.
After fixing KS code only code left is 32 (HAC) And Timing is set at 10.
Thanks for your help
