Hopefully easy question
suprasick
Hey look...a Supra!
Mar 17, 2006
291
Milton, Washington
Long story short I swapped a gte in my na... gte head was toast so I put my na head on. After searching I found lots of info on na cam differences but no info I needed.
Question: Will using a na cam cause a rough idle around 900 - 1000 rpm?
And kinda sounds like a hotrod with cams only reason I ask.
After fixing KS code only code left is 32 (HAC) And Timing is set at 10.
Thanks for your help
suprasick
Hey look...a Supra!
Mar 17, 2006
291
Milton, Washington
Jumpered t and e1
Set engine to tdc through spark plug hole (also matched 0 on timing belt cover)
Aligned mark on cps (followed this http://www.supramania.com/forums/showthread.php?38775-How-To-basic-timing-instructions-CPS-alignment )
Hooked timing light up to number 1 spark plug wire
Started engine and rotated cps till light read 10
Tightend down bolt and re-checked
Also when I got the wire harness it was pretty chopped up and the po crimped the cps wires together (I since then soldered a connector from my na harness) could the po crossed the wires from the cps and the car still run? I did copy the config of the wires when I soldered them.
Thanks for the help
