Hi guys, I got a holset hy35 for my 1j. I have been reading lots of thread discussing the oil lines. And I cannot find a definitive answer especially about the use of a restrictor for the oil feed line. So far from what I understand:
The threads on the holset are m12x1.5 so I will try to find a m12x1.5 to - 4an adaptor. Which I have been googling and I can't seem to find one. Should I be running a restrictor? I read somewhere that hy35's max out at 85 psi oil pressure and iirc my 1j has seen about 90 at wot.
And for the oil drain I will try to weld a -12 and bung to the stock oil pan drain tube.
So if anyone has a hy35 setup on their 1j, let me know what you are using.
