so HX35 are typically t3? i have a 2jzge with stock manifold. the hx35 is the turbo i want to use for quick spool. i am not sure on parts needed to make it fit. so ill need 2jzge t3 manifold? feed line and return what size and where is best place to tap off from for oil supply? any modification needed to the turbo?
thank you
thank you
