running the stock BPV vented atmospherically is bad.. mmmkay? worse than running a real BOV vented. the stock bypass valve is designed to fluctuate between open and closed at idle, and that can make a world of problems for you.
a blow off valve/bypass valve isn't about a cool sound. it's about functionality with the perk of a cool sound. when shopping for one, you should ALWAYS hold functionality over form and sound. ALWAYS.
besides, recirculating helps keep the turbo in spool between shifts...
-shaeff
-shaeff
