HKS Tems controller Question
s383mmber1
3,614
Somers New York
Hey guys!
I need some info on the HKS tems controller. Hard to wire? Direct plug and play? Worth 215? Big difference?
I just need some input from users who have this!
Respect will be given for good answers!!!
:1zhelp:
Pics also help!!1
Thanks,
William
Red Dragon
Keep That on the Down Low
Jan 5, 2006
318
Austin, TX
very easy, comes with harness you plug into stock wiring down by passenger kick panel. Hardest part is taking center dash piece off (easy), taking lower panel under glove box off (easy) and the passenger kick panel off (easy)
so in sum, its easy to install
if having full firm tems is cool to you, then yes it makes a "big" difference. It works as advertised. You can lock it into a mode or put it in "auto" while also locking a mode, but the system will overide for a stiffer setting if conditions warrant. (i.e. you can lock soft, but if you jam the brakes, it will go to firm as the factory system would) (which can be nice at highway speeds on stiffer springs and bigger rims to soften the ride up, although the safety of this can be debated, but just put it in auto then)
and most important reason, it looks AWESOME, and changes pretty colors when you press the buttons
KeithH
Portland, OR
Ahhh the pretty colors........ mmmmmmmmmmmmm
Hell... if you can pick it up for $215 (and wouldn't have advertised that fact here) you could have sold it and made a little profit.
s383mmber1
3,614
Somers New York
Thanks guys! Any pictures of it at night.....?
I would be sooo greatful! O so greatful!
I don't plan on re-selling it!
edit-----------
vBulletin Message
You have given out too much Reputation in the last 24 hours, try again later.
Ill get you guys in alittle while!
Bishop92t
773
USA
www.ma70.com
Personally I love my Tein setup, but if I was still on stock suspension $215 would seriously tempt me. Those HKS controllers usually sell in the $500 range.
