Rennat;1038557 said:i just looked at the sp bolt on turbos... and if there numbers are true, then im defintaley thinkin about those turbos, 490hp at 18psi? thats nuts! it would be the last turbo i buy, but, does it bolt onto the oem downpipe? because i cant find any pictures of the exhaust turbine...
it's a little different. Same flange, different angle.
Make sure its a new version SP. Unless you want to pull it off and do a rebuild every 500 miles. :3d_frown::cry:
