Got alphabet soup all running, runs good so far. Short story: the gain knob on the vpc works, the option out knob does not. SW2 in the fcon is set to 0, setting it to 1-9 runs it a bit leaner but there is no difference between any of those. Option out wire from VPC, when hooked up to the fcon, does the same thing...knob doesn't work, 1-9 there isn't any change. Currently have it on 0.
Long story: bit of a mess because I bought everything separately, so it's probably a wiring issue.
FCON was installed first, then a FCD. I then bought a GCC with a patch harness for the FCON, that worked fine as well. I bought the VPC a while ago and just got around to installing it this weekend (thanks Gordon!).
Now: The VPC is spliced into the FCON harness using the HKS splice connectors. The GCC wires are NOT hooked up to the VPC, they are still in the patch harness to the FCON. HKS docs say this shouldn't be the case. 5 wires on the VPC connector side, and 5 wires out of the GCC...but the colors don't match up so I don't know what the hell to do there anyways.
When I hooked the option out wire up to the FCON from the VPC I had to depin the yellow wire from the GCC patch harness (going to the GCC) and slip the brown option out wire in. As I said before, made no difference.
Everything else is hooked up as it should be, and everything else is working fine so I'm thinking it's just this GCC not being hooked up to the VPC...but before moving any wires I'd like to know the colors and why it won't work this way, but will work the other way.
Thanks for any input!
