High volume oil pump
IBoughtASupra
4,455
Queens, NY
I am not sure of that but I would assume the PSI it generates past 8,500 would blow a seal then. The TSRM says at 3000 RPM, you should have 47 or more PSI. On my 2JZ, I have done 7,000 RPM pulls and my Defi's show 4.5 bars which is 65 PSI, and I am on a stock oil pump with no midifications and seals are fine.
