high revving
cruzinbill
SC3TT
Jun 26, 2005
515
Arkansas
what is the highest rev a built 7mgte should be capable of because iam currently getting my head done and next is the low end im wanting to make a high reving project what do u guys think would be neccasary to do it
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
Full valvetrain replacement; Ti shims/seats/springs with Ti valves too, why not eh. Make sure they are +1 oversized, and port/polish head, 3+ angle grind on the valve seats. Get a 5m crank to destroke it from 3 litres to less so it revs faster. Somebody else fill in the rest.
eric
figgie
Twin Cities, Minnesot-ah
let see
if the valve train can take it
91 mm stroke.. perhaps an easy 7000 rpm on stock bottom. Built bottom 8k easily (BMW S54 has same stroke as our car and a 8k redline from factory ;) )
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
Meticulously balanced and couterweighted steel billet crank, titanium rods and wrist pins. If thats done right (IMHO) probably wouldn't have to de-stroke.
But for really high revs I think you would have to incorporate a valve train that in addition to being more stiffly sprung , lighter (sodium filled valves etc.) and stronger would eliminate or at least modify the shim spacer set-up as they will "spit out" at around 7k rpm's for sure and sometimes alot less.
cruzinbill
SC3TT
Jun 26, 2005
515
Arkansas
Well for the head the folowing work will be done soon pending my valves coming in ported polished head 3angle valve job combustion chamber will be smoothed out more gasket matched intake exhaust ports tit 1mm or 2mm over valves i cant remember at the moment dual valve springs tit retainers oh and everything will be cryo treated also but i cant say i have found a crank like that or rods but if some one knows where that would be great
p5150
ASE and FAA A&P Certified
Central Idaho
save yourself some $$ and keep your stock valvetrain. Your bottom end will have problems with RPM before your head will
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
Are all these suggestions just hearsay and speculations, or has anyone actually tried to run high rpms. Someone that has actaully done it, please chime in......
figgie
mello has ran 8k rpm before
one guy datalogged his supra with a haltech
10.2k rpm at one point but he won't try that again :)
ChevyEater has run to 8K and my motors pretty well a clone of his so I have no concerns about spinning it that hard once it's together.
It's NOT something I'd try on a budget build though.
cruzinbill
SC3TT
Jun 26, 2005
515
Arkansas
why what happened figgie and by the way guys my goal is 9 ill settle with 8 if the bottom end cant handle it either way i want a bulletproof head and what would u guys say are the downfalls to using the 5m crank
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
cruzinbill said:
my goal is 9 ill settle with 8 if the bottom end cant handle it...what would u guys say are the downfalls to using the 5m crank
9K is alot of revs. Especially for a 7m. Everything has to be just right or kaploooeeey!!!
With all due respect you should build some engines and get some serious working knowledge before you even think about 9000 rpm's.
If you have this many questions on what it's gonna take to do the do (in this case 9k) you are not ready to tackle this kind of mechanical undertaking.s
Save yourself some money and alot of grief and work up to a goal like this, otherwise you'll spend a ton of money, probably not get what you want and become a very frustrated Supra owner.
Just a word to the wise...
cruzinbill
SC3TT
Jun 26, 2005
515
Arkansas
well #1 i have built up many engs and for high reving 2 my 3TC-T is at 10 and it is pushrod. The only reason im asking is what the highest anyone has went as u can see in my first post im wanting to see what differant people are using that is why i waited till after some people said some things before i said what i was already doing to the head cus some people wont use their own judgement or opion when u post what u r going to use so i just wanted to see that and as for money well knowing the right people saves alot of money for sure the head is gonna cost me 800 parts included Well other than that yah i understand what u r saying about things and agree with u
Charlie97L
230
Clarksburg, MD
what is honestly, the point of revving a turbo engine to 9K? there aren't many turbos out there that will be able to keep up with that kind of powerband (ie. not run out of breath by 9K) and still be decently streetable. are you building this up for a certain application?
i mean 9K is s2000 and rx8 range... i just don't see the need, other than bragging rights. but that's just me. 8k would be a lot easier, and probably give you just as good of a power curve. 8K is still damn high. just my two cents.
cruzinbill
SC3TT
Jun 26, 2005
515
Arkansas
well with the turbo i am running i dont plan to have full boost till about 6k so im not worried bout it running out of "breath"
figgie
absolutly nothing :)
but 10.2k on a stock bottom end ;) not that smart especially with the loads seen at that rpm.
cruzinbill
SC3TT
Jun 26, 2005
515
Arkansas
lol only reason it isnt past planning is because im not back in the U.S. untill i get back im buying the parts needed and when i get back ill finish up my bottom end. everythin else i have done thats why i was askin to see if there may be things i overlooked
