I'm trying to plan out my power steering system. I know that the line from the pump to the rack will see high psi, so I'll need lines capable of the task.
My question is the lines from the rack -> cooler -> resevoir, I assume that these lines will see significantly less pressure so I can use regular oil lines capable of 350psi. Is my assumption correct?
