well 400 for a turbo is like An eBay turbo which will literally like blow up haha
if it helps when I had that turbo I sent a pic of on mine it was smoking sooo bad about a court of oil every 3-4 days bad
and it has horrible shaft play
the cxracing turbos are never instock
driftmotion sells a 57trim ct26(extremely common upgrade which I have) it's about 700$ I think
it's a good turbo
stock turbo with upgraded compressor wheel
you can hit 375 with what you want with the 57 trim with a really good tune and pushing the turbo at 15-18 psi
if you still want bigger look at the bolt ons that sound performance sells..if you want a bolt on
going t4 takes a lot of you're on a time schedule
it's a good turbo
