High boost, turbo pipes blow up!!!
Allan_MA70
1,055
Melbourne, Australia
7MGTEJoe said:
Your concern is well placed (I had similar thoughs when I first read it on the sogi list) but this dog was beaten to death years ago. John actually ran tempature tests and has pictures here if you care to ready a litle more about it:
http://www.jblmk3.com/id1_custom_jblmk3_intercooler_pipes.htm
Continuous Service Temperature - in Air (max.) for pvc is 160f or 71c
the supra engine bay is WELL above this frequently!
its just dum to save $20 and use pvc when mild steel is soooooo much better suited to the application, its ALLWAYS better to opperate with a margin of safety!
Whats your car / time worth?
Its GHETTO
Its BAD engineering
Its being a huge tight ass
Its painfull to look at
chriso
Supranian
Bay Area, CA
Looks clean, but I would paint it silver or black to match the rest of your engine bay so it wouldn't be so noticable from Home Depot. As long as it works Right?
Allan_MA70
1,055
GrimJack said:
Allan_MA70, you've made your point.
kick this for me will you :stickpoke:
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
looks like you used sillicone sealant instead of pvc glue??? maybe try the correct glue but gees man.. :3d_frown: i prefer mild steel so i can weld up a 1/8th inch bead around each end of the IC pipe to prevent each hose and clamp from NEVER slipping off again... and steel or aluminum pipe is tuff and looks cool too. Pvc is made for turds to flow on gravity only, not boost friendly..
good point on the heat shield , use it...
my 4-5 cents..
JDM 1JZ
I hate Tires
Aug 31, 2005
301
Cherry Hill, New Jersey
Not trying to be a hater but in that picture i see no heat shield. but if its working for you i'd invest in a can of spray paint.
well that my 50 cents (G-Unit)
J/K
boost fiend
852
Rockford, Il
LMAOROFL!!!!!!! in a very sick and demented way i can agree with both sides of this very beaten horse. some people just have to be the one to try somthing diffrent while the other kids on the playground point fingers. i give fella 1 brownie point for atleast trying. i give the rest of the group 1 brownie point for making me and everyone at the shop laugh till our guts hurt.:biglaugh:
