white1jz90;929959 said:
i have a ? while im on here im ganna have a resistor pack wired into my harness by 935 and use 2jz injectors is there anything else i need to run the injectors and will i need a safc to tune them and how do i get rid of the fuel cut?i saw it at mdc and they weere using a garrent wheel and quoted it at 435.
to get rid of fuel cut you will need a stanalone or just get a bcc ( boost cut controller) the .57 trim ct26 is good for 400+ only with the right tuning, 400 is actually pushing it. its a really tiny turbo, if you want more power you should go with a bigger turbo, again the ct2657 is good for poor students such as myself, its a bang for your buck. i just wanted to mention that your going to have to get cam shafts; im guessing 264 or 272 depending what kind of upgrade your going to be doing in the future. I would say with all the mods 550's, afc, ddp, bcc, ebc/mbc, wideband, higher flow fuel pump, afpr and fine tune the fuel system i would be guessing 400+ with that little turbo, but if its street tuned no way you will be seeing that 400.
edit: you can wire up your own resistor pack, its here somewhere (search) btw are you talking about 435bhp or 435whp?
