jdub;1016470 said:I also have the one from Exhaust Depot...works as intended
jdub;1016493 said:A metal CAT (Exhaust Depot) will flow better, but the metal substrate can be damaged if you go lean.
The ceramic substrate CAT is more corrosion resistant.
I'm pretty sure the Exhaust Depot CAT is a 2-way (CO + HC), most modern ceramic CATs are 3-way (CO + HC + NOx)...the 7M came with a 2-way.
Efficiency is going to depend on the substrate wash coat on either the ceramic or metal CATs.
The CATs you linked to do not have flanges...are you planning to weld your own?
Blade2001;1016688 said:I have Random Tech 3" high flow cat. Car didnot pass emissions with 550s and lexus AFM. With stock fuel and AFM, car passed with this cat.
