Hey, what the hell do I do with this overflow bottle?
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
So I was messin with my radiator overflow tank, I dunno where to put it... You guys with the big FMICs, where did you mount your overflow tank?
You know what else I was thinking, what if I just got a smaller, maybe polished overflow tank that would fit, but then I was thinking, that overflow sensor: where would I put it? Because I dont want to drive around with my birdcage light on all the time... But then I thought, I could just pull the bulb out of the dash where the birdcage is, but then I thought, its a good warning system, so if I could somehow transfer my sensor to a new tank... THEN I thought, well, maybe someone sells a nice overflow tank with a sensor all ready in it, so I can adapt it to my plug...
Thanks,
Jake
empera
Authorized Vendor
Philly.
actually the birdcage wont be on if u disconnect it, im running an aftermarket overflow bottle even tho i should change it because its pressure type but i drilled a hole on the top and extended the pick up. anyways my birdcage never shows and its been disconnected for a while, you can also try to put the overflow in the engine bay. some people with FFIM put it where the battery belongs if they relocate it.
tissimo
Stock is boring :(
Melbourne, FL
I threw mine in on my car where ever it fit.. its zip tied right by my filter and charge pipe.. the overflow tube points right into my filter for water injection (not really, lol)
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Emp/Hells: I thought about putting it where the battery is, but then I cant run my IC piping through the hole I made... :(
Kieth: how big is your FMIC?
Justin: zip ties? :nono: hahaha
tissimo
Stock is boring :(
Melbourne, FL
zip ties are your best friend! lol.. its temporary until i find something else (more like once it breaks and forced to do something else)
