Help!!!!!!
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Black box is the same, so if you put that on your existong AFM, then it'll work exactly like stock, and you'll have the Lexus AFM body for when you get the larger injectors.
JStoked
646
Edmond, Oklahoma, United States
AHH yes the black sensor on the top that has 3 screws holding it in. If that comes with your new afm take it out and put it in your stock housing. Then put THE STOCK HOUSING ON THE CAR!!!!!! Is that easy enough.
jonahs_supra
1,015
Lancaster, Ohio, United States
so did you ever check for boost leaks?
i mean with a boost leak tester
need a little better description then"runs like shit"
does it idle good?
does it rev good?
when does it run like shit?
does it run ok when driving like a grandpa?
checked for codes?
exhaust smell rich?
when the car stops at 2500 does the CEL come on for 3-5 seconds and then go off?
can you make a video of what your car does while idling? driving?
laxboy36
282
Chesapeake, Virginia
idles is never at a steady idle, CEL does come up for 3-5 seconds and then goes off. lean as fuck, runs ok when driving like a old old grandpa, rev wont go past 2500rpm. no codes
Turbo Habanero
4,229
Tucson,AZ
CEL comes on but there's no codes stored...
CEL coming on when you come to complete stop and turning off as soon as you start driving again is a problem i had when my TPS started going.. CODE 41
