Help
ska_ponch
27
Mo Val
idk wat just happened to my supra one min its driving fine and next thing i no it starts smoking out the muffler and also dripping oil any ideas wat it can be
leecheater
Got a bad habit
Mar 27, 2006
458
St. Cloud, MN
You probably are leaking oil onto the exhaust system. Jack her up, put her on a hoist, what ever it takes, get under her for a look. You have to give us more of an idea where it is leaking from. Do the basics, if you can't find an answer, then post up.
Supracentral
12
ska_ponch;1574262 said:
ok o and i forgot to say that the oil was coming out of the muffler
There is really only one way for oil to get into your exhaust on a non turbo car, damaged internal engine components. Getting under it won't tell you anything, you need to start taking it apart. Start by pulling spark plugs and see if one of them is oil soaked. From there you'll need to do a compression test to locate which cylinder(s) are having issues. You've either blown the head gasket between the oil & cylinders or you've damaged something internally. Regardless, you'll need to take the motor apart.
