help
7down-7m
59
milton
i borrowed tools from "injector doctor" a shop based fully on injectors and fuel . . used the nodes to test
rly im starting not to care anymore . .thinking about just listing the car and cut my losses still undecided tho
7down-7m
59
milton
the nodes i used to test the injectors was to test for "injector pulse" or something like that and i came back negative
7down-7m
59
milton
ok well it starts finally but does not stay started 10 seconds or less unless someone feathers the Throttle after i start then it stay on about 2 mins
ran codes only thing i got was code 14
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
honestabe;1445507 said:
It might help to post in the engine section bro, this section doesn't see much traffic.
^Agreed...
Does your ISC make the clicking sounds when you turn the car off?
Have you messed with your TPS at all or is it in the factory position? It may need to be adjusted.
7down-7m
59
milton
well the guy that had been coming over helping me showed me i had the ground wire that goes to the intake mani . .i had it hooked up to my starter power post thing and that had shorted out my ecu .. he brought an ecu over for me to test with and it started and ran just fine . .i might need to tinker with the idle a little bit but i need to take my top end off and check all the valves and valve springs and everything top end ..there is something there clanking .. no not rod knock ..its to high for there its something top end so once i can clear out the junk that is in the garage i can start tearing that apart
and if anyone htat reads this happens to sell an ECU for 89 turbo m/t send me a pm about that
thanks guys
7down-7m
59
milton
oh haha well i dont think i will bother with a new thread quite yet because i think i got it pretty much figured out . . i know i have to tear apart the top end and check all my valve shit and replace the ecu but if there is any other problems that i run into along the way i might go and post a new thread in the engine section but i am still taking any input i can get
