I did a 1j swap a while back and used the tach from the clip but it seems to be off. On the dyno the car hit 7000 and the tach read about 4800 so I think it only reads 2/3 of the actual RPM. Anyone know why this is? I swapped it into a 87 n/a chassis but thought it was supposed to work. Could it just be a faulty tach? I'm also curious, if on the gte's on the connector that goes into the gauge cluster behind the tach if there is a wire in the third slot. My n/a body harness has no wires in the 3rd and 4th slots and I know the third one goes to one of the 5 screw connections from the tach on that green super thin circuit board thing for the cluster. Help Please!
P.S.
sorry if this is confusing.
T.I.A.
Derek
P.S.
T.I.A.
Derek
