What pedal switch?
Do you want to wire in the Pedal switch? That is done in the car requires you to cut the starter signal coming from the key and wiring it inline to the switch at the bottom of the pedal.
Just listen to me and jumper the Big White and Black Wires on the harness with 3 terminals. Because when the key hits start on a automatic car the signal is sent to the white wire to see if it's in park or neutral then the starter.
