help with fuel regulator which to buy...
mk3tattoos
1,104
Bremerton, Wa
i realy liked the SX racing AFPR! i had it on my 7m and plan on getting another one for my 1jz, i know of a few cars that are very high hp that use them with no problems from them.
Oct 11, 2005
3,819
20
Thousand Oaks, CA
Some installation advice... AFPRs should be mounted to the engine. This prevents fuel leaks in an accident should the engine mounts break and the engine shifts. An AFPR mounted to the chassis can snap a fuel line under those conditions.
Also, be careful about routing braided stainless lines. If they rub against something they will quickly wear through it. If that something is the alternator wiring, a nasty fire can start. Its been documented a few times already on this site.
