help with BOV
jester1341
topless and blown
Western Maryland
i just got my greddy type-S in the mail :D and noticed it has two(2) vaccum line fittings? one of them is the vaccum to opertae the valve and the other.....i dunno it allows air to move thru the chamber with the valve closed.
john
MDCmotorsports
Indy 500
www.MDCmotorsports.com
I think...
The bottom smaller one is a vent. You can hook it up if you like ON THE BOOST SIDE before the valve body.
The top one is to opperate the BOV. It goes AFTER the throttle body.
jester1341
topless and blown
Western Maryland
MDCmotorsports said:
I think...
so, the vaccum one goes to a plain vaccum line like from the manifold and the smaller one 'can' be hooked to say the IC piping. now i assume can means it dosen't have to be. if i don't should i cap it or leave it open?
john
JesseH
1,153
Englewood, Ohio, United States
I have the Type-S too. I love the thing out of the others I have used. I also have the bottom port hooked up to a boost ref. The reason why that second port is there is to use the positive pressure to push up on the valve while the vacuum source pulls. By doing this it creates a faster valve response to fully remove compressor surge. I left the bottom port off at first with my 60-1 on the car and got surge in lower boost levels. With that port hooked up it took care of it all.
Heres a pic of how it works:
Nghty89
Zombie Chicks Are Hot
Mar 26, 2008
978
7 Cities, VA
Thank you, that's a good explanation :icon_bigg Looks like I know what will work best with my T70 now :evil2:
By lurking, he means shut up and learn :sarcasm: Supras tend to be unusual cars when it comes down to things and just assuming things about them will get you in serious trouble. Trust me :biglaugh:
JesseH
1,153
no problem:icon_bigg, and don't worry about that guy....he won't be posting on here anymore....:sarcasm:
