Help with bolt issue!
s383mmber1
3,614
Somers New York
Ok guys, i was removing my exhaust manifold today on my 7mge and i got to the LAST one and bam, stripped. Can even get a grip on it AT all.
I am sooo stuck onwhat to do! Any good suggestions as what to do? I searched and came up with very litte! Im stuck!
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
can you get some visegrips or anything like that on the bolt...or even cut the head off? If you have a welder you could weld a nut to the end of the bolt and most likely get it off that way.
s383mmber1
3,614
Somers New York
Its a really really tight space and i tried the vise grip idea, no luck what so ever.
I kinnda got frustrated and gave up for now, im gonna go at it later tonight.
No welder here!
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
in tight spots like that, things get pretty limited...just don't get too pissed off and do something stupid...no matter how bad you want to you will regret it later.
s383mmber1
3,614
Somers New York
Yhea , i was gonna jsut rip the manifold off and break the bolt, the ni desided i would definatly regret that later.
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
if you have supra buddy just kick him...thats what I do...kick him and say mean things about his mother!!! thanks for being there Matt..
mkiiSupraMan18
Needs a new username...
United States
^ Yeah, Jason pwns Zach's mom...
I would try to get all the other studs out on the mani, and pull up on the manifold like it was a giant ratchet, I've broken small brackets loose like that, and I'm sure the same concept applies... I wont promise that doing that wont screw something else up, or make matters worse, but it should do the trick I would think.
s383mmber1
3,614
Somers New York
Thats a good idea, im gonan try it tommarow if i cant get my new idea to work. The only things it ite my headers, there for i would have to move the entire half of the exhaust up and down. lol, ill give it a shot, if not, im off to sears!
And Tubbie, your being seriouis about it? Or your being sarcastic? Im definatly going to purchase this if it works!
Will: You have a few options, you can buy the Tubbie tools or a Needle Socket but the low cost way is to get either a small cold chisel or a screwdriver you don't love and a hammer.
Place the Chisel at the outer edge of the nut and tap with the hammer making sure you have it facing the direction needed to loosen the nut.
A few whacks should crack it loose and as the nut is cootered anyway it doesn't matter if you damage it more!
s383mmber1
3,614
Somers New York
My only worry about this is if i hit it and it brake the bolt in half. Then im in worse condition than i am currently. But ill give it a try if all else fails.
You're hitting the nut on it's outer edge so there's no load going into the bolt! (no way will you break the stud off)
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
i agree with IJ, tapping it is probably the best way to go. if you wanna make it easier try and get a dremel in there and cut a notch to fit the screwdriver slot in. then just whack away...
s383mmber1
3,614
Somers New York
Hey thanks guys, i really appreciate it.
And Ian, im SURE youve heard this before but you are very informative!
Ill letchaguys know the out come of this!
Thanks once again!
