i have a 1987 supra with the stock ct26 turbo and all i have done so far was 3 in exaust from turbo back and intake it has 122 thousand miles on the motor and im shooting for 450 to 500 hp but i dont know what to do next?? i would like so advice!!
supracrazey said:i have a 1987 supra with the stock ct26 turbo and all i have done so far was 3 in exaust from turbo back and intake it has 122 thousand miles on the motor and im shooting for 450 to 500 hp but i dont know what to do next?? i would like so advice!!
IwantMKIII said:H.G. CHANGE
Atleast! Otherwise rebuild now while you have the money.
Afterwards: search button
CKanderson & GrimJack said:Stage 0
Basic maintenance. Don't even start until you've checked all the vacuum lines, coolant hoses, and everything else that is going to head south on you the instant you try to add performance to a 15 year old car.
Stage 1
K&N high performance air filter kit
3 inch down pipe
3 inch exhaust
*Optional* Test Pipe
*Recommended* 12 volt mod for fuel pump
Stage 2
Stage 1+
HKS BOV kit, or equivalent
3 inch turbo elbow
Boost controller
*Recommended* Shocks and springs
*Recommended* Brake upgrade (pad's, and or lines)
*Highly Recommended* 3 inch test pipe, or high flow cat
Stage 3
Stage 2+
Intercooler Kit
Hard Pipes
Metal head gasket (required at this stage, may be needed for earlier stages)
ARP head studs, or bolts (studs recommended)
Walbro 255 LPH fuel pump
*optional* Fuel pressure regulator
Stage 4 TUNING REQUIRED (Wideband, on a dyno)
Stage3+
Upgraded CT-26 (stock) turbo (57, 60, 60-1 trim)
Lexus AFM
RC 550 cc injectors
Fuel controller (e-manage, Super AFC, F-con)
Upgraded clutch (spec stage 2 or greater)
*Highly recommended* Bigger brakes
*Highly recommended* Coil Over's, and sway bar's
