jizake1jz said:
If i have a roll bar and stock seats, can i run a harness safely? if yes then 4 point or 5 point (i think he suggested 5 point).
any harnesses you guys reccomend? i would want a 3 " harness, correct?
If you're just getting this becuase you think you'll be more safe on the road with a 4 or 5 point, then do not get it. This should only be in your car if it's a track only car. You can do a lot of damage with this in you daily driver if you wreck, look up spinal compression. Not to mention you'll need to have a hahn's (sp?) harness on at all times to prevent your muscles in the back of your neck pulling your skull apart if you have a high speed wreck and are using this harness.
Edit: If you're confused on that last sentence, do a search on Dale Earnhart (sp?) Sr.
