Nothing! Battery is good. The windows roll up and down, and lights come on and all...starscream5000 said:No click or anything?
Its about 35mi away. Even if it did start Im still going to need it to start again..Burntz said:Sneak back later in the night when no1 is on the highway and try push starting it![]()
Dont mind doing that, but again Im still going to need it to start all the time. Its my DD. If it doesnt start Ill go get my uncles roll back so getting it home isnt a problem....johnathan1 said:Direct power to the starter, or push start.
Aspec said:Roll your windows up. Shut the doors. Go to the passenger door. Using your key in the door lock, twist the key to lock the doors twice. Now wait for 20-30 seconds. Now unlock the passenger door twice but do not open it. Now go to the drv door. Unlock it, get in and try to start it.
No go... Same results... If I unhook the PCM and plug everything back in would that help? Maybe like reseting it or something?Aspec said:Roll your windows up. Shut the doors. Go to the passenger door. Using your key in the door lock, twist the key to lock the doors twice. Now wait for 20-30 seconds. Now unlock the passenger door twice but do not open it. Now go to the drv door. Unlock it, get in and try to start it.
Just printed everything off and Im about to go do that... Ill post the results in an hour or so...starscream5000 said:Try it and see. Did you attempt to bypass the system like mentioned in your other thread?
Z'mnypit said:No go... Same results... If I unhook the PCM and plug everything back in would that help? Maybe like reseting it or something?
It was... I locked the pass door, then turned the key in the same direction again. Waited 1min, unlocked the pass door, turned the key in the unlock direction a 2nd time then unlocked the drivers side door. Then tried to start. Nothing!Aspec said:Forgot to mention... Make sure your hood and your hatch are closed before you try to reset the alarm using the procedure I gave you.
Z'mnypit said:Removed the ECU, reinstalled the ECU and tried to start and nothing. I honestly have no clue what the hell is going on with this car....
