please read if you have the time long one sorry....:icon_sad:
so maybe like 5 days ago my engine light came on i pulled out three codes, 22,42 and 51
22...i know its on because of my temp sensor i have it unplugged for a reason.
42...Vehicle Speed Sensor Signal ive been tinkering with it.
51.. iam just not to sure about. i was reading it would be linked to something with the a/c? or the TPS?? i have disconnected the compressor maybe that a hint.? i have also switched tps with an extra maybe i should get a new one...
The issue she is having is when i turn the key to start her up she will just crank and crank ..ill stop crankin it and turn again,most of the time it takes two times for her to turn over when she does its idling rough as hell around 500 rpm then if i touch the throttle a little she will clear up and raise to 8-900 R's. The weird thing is if i raise her up past like 3g's you can what sounds like the flapper in the VAF closeing and it tries to stall until i let off the throttle. in other words,if i kept my hand on it the engine would just die when i let go it catches and evens out.
I have also just noticed a oil leak from behind my engine look in picture for view.
when rebuilding my kit came with that gasket so i replaced it but now its covered in oil and been leaking alot i can see it on my tranny. i hope i not have to pull it out to fix it. but iam pretty sure its some sort of pressure plate might be related to my problems. please let me know what you guys think thanks .
